I need to run a new ring main (2.5mm) and a single spur, also 2.5 mm. Can I place all three cables in one channel I cut into the stone walls for the "main run"? They will run a few inches from the ceiling, and I may cap them pro forma. I will cover them with plaster.
Also, do I need conduit for the part of the run that is
1) in a boiler cupboard
2) behind semi built-in appliances (washer & dryer): with a counter top above them, and side panels.
Many thanks,
Many thanks,
