Hey I have a central heating pipe that is leaking its 15mm copper its leaking from a solderd joint so wil need draining down etc. How much roughly would a plumber change for this?
I recently had a plumber replace a section of crushed pipework and two new tails to a radiator I had fitted, cost me £60 for 2 hours work, I had already drained the system down and the floorboards were up, I would have thought two hours labour max if the job is as straight forward as it sounds.
