how much is a diverter valve
28 Feb 2009
Birmingham
i apparently need a new diverter valve because the pressure drops when cold water is run.
just wondered how much people charge as i have been quoted £220 for the part
i have a ferroli modena 80e
Unless you can see a visible water leak from the DV, I can't see how changing this will solve your pressure problem, especially as you have been told it's because cold water is running through it :?
Don't keep starting new threads for the same problem.
It is very confusing. :roll:
we have had an ongoing problem and the expansion vessel and prv have been changed as water was leaking out of pipe out of wall however that has now stopped but we are still losing pressure
this is made worse when we are showering (its an electric shower), or running taps etc and the plumber said that proved it was a fault with the diverter valve.
does this not seem correct?
ask the plumber to show you the divertor.
:idea: :idea: :idea: :arrow:
he will have a job as the modena has none. :lol: :lol:
No No No No No how the hell can your electric shower effect the central heating pressure.
The guy is an half wit.
Is this a wind up :?
Good point, I didn't think to check this :oops:
That proves our point though :lol:
sorry about new thread thought seen as it was a new topic should restart but i will take note in future.
if i dont have a diverter valve what the hell is going on with boiler!!! he turned the cold feed off to boiler and pressure stayed up when he turned it on again it started dropping
