How much more space do pocket doors consume in terms of width compared with non-pocket door plasterboard partitions?
Youre not serious are you?Wot's a pocket door?
My builder seems to think that I will have to double up the partition so that I have to have 100mm one side then the door of (however thick) then another 100mm. is that wrong?As woodhead they will fit in a standard partition ........ here's one I did earlier .....
What does your detail show?My builder seems to think that I will have to double up the partition so that I have to have 100mm one side then the door of (however thick) then another 100mm. is that wrong?As woodhead they will fit in a standard partition ........ here's one I did earlier .....
Deadly.Youre not serious are you?Wot's a pocket door?
The extent of the architect's drawing of the pocket door on the en suite.
That's not a pocket door. It's a sliding door
Do you need glasses? Or have you missed the detail posted in this thread?But question still stands - is it true everything has to be doubled up? 100mm on both side of the door plus door thickness? Minimum either side would be what, 40mm instead of 100mm?
