Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Assuming you mean the gap between the bath & the underside of the first tile leave a 2mm gap (standard tile spacer). Fill the bath with water before you silicone, leave overnight before emptying the bath to let the silicone cure.
Same gap; usually based on 2mm tile spacers. In a wet environment (baths/shower cubicle), the corner joints where the walls meet are best siliconed rather than grouted as differential movement between the two walls can cause grout to crack.
