Hello all,
Having just moved in, looking at the consumer units, they are getting on a bit, and require a lot of space. There are two main units with push button MCBS. In addition, there is another box with switch, plus an RCD box, so as you can imagine it all takes up space. I also need to put in a 32A or so line to my garage (and another one to a future garage to be built). Mess is due to I think three extensions to the house in the past!! In total there are about 16 or more MCBS present (I'lll need to check - will post a piccy if I can get one)
What sort of cost should I expect to have to pay to get a leccy in to do this replacement job and also run a cable to a unit in the garage (I'll wire the garage myself - just need armoured cable to a box)
James
James
