Surprised nobody mentioned the absence of grommets on the back box...
Just checked. £1.10 domestic cable, £1.10 lead. Even stevens currently. They seem to have swapped over month on month as to which is more valuable, on the off chance it's 10p more per kilo when I go for a weigh in, it's not worth keeping separate.No mate lead is definitely worth more now, at least at my local.
As you say, opinions undoutedly vary, and are sometimes 'strong' but my personal opinion, for what it's worth, is that the short answer is 'no' - so long as it's PVC cable (with an earth!) and is exhibiting no problems to most likely of which would be physical damage, I don't think there is currently anything we know that indicates that it should be replaced solely because of its age.I was watching a youtube video (a well known electrical blog) and he was pretty amendment that any wiring circa 40 years old should be replaced, no question. However, I have often found the answers on this forum a bit mixed on that subject. So, I was wondering, at what point does a rewire, if the installation is not dangerous, become something that should be done due to the pure age of the installation, regardless of condition.
As above, that would be opinion unless/until we discover things (about very long-term behaviour of PVC cables). However, as you say, the reason for 're-wires' is often not primarily because of the cables.Or, if at the end of the day, if a cable passes the required tests, is it pointless considering a rewire, or a waste of money?
That is certainly another one where there are (often strongly) polarised opinions. We don't 'need' ring finals, and they would probably not be allowed of if they had first been thought of in recent times, but they have given many decades of service in tens of millions of installations without any real problems and, despite what you say, are (I think) probably still the most common type of sockets circuit being installed even today. One would have to think hard to come up with any particularly significant differences, either way, from a householder's perspective.I am aware than a ring final wiring design is no longer the preferred method of wiring a house. Does modernising from that set-up bring potential benefits as well?
I'm afraid that's a 'crystal ball' question. As far as I am aware, we currently have no reason to believe that PVC cable (provided it is not exposed to UV light - like outdoors and unprotected), could not remain satisfactorily in service for 100 years or more. On the other hand, in the next decade or two we might start seeing problems with some of the early PVC cables..... The consideration is therefore, to save a bit of money do we incorporate the existing wiring into any new additions and/or changes. Updating only the things that really require updating (consumer unit etc.) .... Or, considering the scope of the renovations, is this a false economy in the long term?
Indeed - but, as above, neither of us has a crystal ball. If 'money were no object', the 'safe' course would presumably be to renew all the cabling 'now', whilst an opportunity exists - but few of us mere mortals are really in the 'money is no object' category - so I'm afraid you will just have to make a 'decision' (even if it's not much more than a guess!). I hope that the passage of time shows that you made the right one!As this is likely to be a one off refurb which will probably see the property staying in this state for another 40 years. .... Decisions....decisions....
Indeed. I observed earlier that there are often good reasons for a 're-wire' which have nothing to do with the condition and/or life expectancy of the cable.Whilst I agree with John and do not believe in doing things just for the sake of it, the likelihood of incorporating the present wiring into a new design may be more trouble than it is worth.
After all, it may be all bits and pieces now.
We can't really know without examining it.
