Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
James, if the new plug is leaking even when its fully down, then either its the wrong diameter or the 'o' ring isn't there......I suspect the former.
At the end of the day, if this is the case, its better to fit a complete new waste which comes with a suitable plug.
John
Have you studied Charnwoods picture post, James? The adjustment mechanism is shown.
If the plug still leaks, its not the correct diameter I'm afraid - although it will seem very close.
John
I've no idea what the rusty, non adjustable plug looks like - was it the original one?
There's always a degree of adjustment underneath (Charnwoods pic post again) to compensate for this.
There's also no guarantee that a plug purchased from Amazon is completely suitable for your waste fitting - its the luck of the draw.
John
As in the diagram you may also need to adjust the operating rod along with the adjustment screw under the plug to obtain the correct setting. It's just a matter of trial and error - no magic solution. Just make small changes until the correct fit is achieved.
