We're building a warm roof on our cabin. The main roof structure has substantial purlins running along the roof at 80cm centres, boarded with 20mm planks to form the sub deck and covered with a VCL.
We have 120mm PIR boards which will be sandwiched between the sub deck, and a top deck (OSB or marine ply).
So we plan to screw through the OSB,PIR and boards into the purlins I guess using 150mm+ screws.
How can we ensure the screws hit the purlins? Even a slight angle and at that length they'll miss and poke through the roof.
Warm roofs are not so common in the UK but are elsewhere... Is there a trick to it? Our contractor was discussing with me he's not confident doing it by hand.
