How to attach climbers to walls
16 Jul 2006
Lancashire
Hi !
I'm new to this forum and am wondering how to attach my climbing plants to old brick walls. I bought some plastic netting but couldn't find the 'fixings' to attach it to the wall. A year or 2 ago I had some T shaped things that screwed into the wall and the netting clipped into them but I cannot find them any more.
Any ideas please?
I am no DIY expert, by a long chalk, just a lady trying to improve her garden
M
Hello and welcome to the forum :)
The way I would do it would be - get some small screws and raw plugs - drill holes into the brick (you could drill into the mortar, but probably safer going straight into the brick in case you crumble it).
Then just attach the netting to the screws.
Another option - although I have never tried - is get some strong adhesive (like No More Nails - outdoor version) and glue some hooks to the wall.
Good luck,
Gary
are you sure you really want to do that? most climbing plants "attack" the mortar, ivy is a good example
if your mortar is soft enough, you can buy "climbing nails" from most garden centres. these are a short fat nail with a cast piece of lead on top, and a piece which comes off to allow you to hook it around the plants, or the netting. Ill try and find a picture when ive a little more time
Not all climbers will attack the walls, eg jasmine honeysuckle etc.
I would use Masonry nails and tie the mesh to the nails with garden wire. Would be the cheapest solution and easiest to remove if required at a later date.
I like Vine Eyes. These screw in rather like a very long (and thick!) cup hook, so you need to drill a hole in the wall and insert a plastic plug. You can then tie rope, string or wire to it according to the size of your climbers. Rope or webbing is less likely to cut into the stem.
I'm not keen on nailing into walls as this can crack the bricjk or mortar.
Would you believe it !! Went to a store in a differnt town and found just the T fixings I have been looking for for months !! Problem solved :)
Thanks to all who replied- very helpful.
M
