How to connect 40mm compression fittings to this boss?
5 May 2007
Edinburgh
Can someone please advise me how to go about connecting this boss to 40mm compression waste pipes?
The existing shower and whb waste looks like 40mm compression fittings.
I think this is the boss I need - its the "82mm Soil Patch Boss 40mm" from Drainage Online:
https://www.drainageonline.co.uk/ab...ush-fit-soil/82mm-soil-patch-boss-40mm-sws340
How does the 40mm pipe fit onto the boss? Will it be simply with a compression fitting? Or will I need some further adapter to connect 40mm pipe to the boss?
Ian
Here are photos of the 40mm waste pipe and 82mm soil pipe:
Soil stack running down recess in brickwork (a strap on boss might not fit):
full
This the vent part of the shower and WHB waste pipe. I need to temporarily divert this waste to the new boss as the existing 40mm waste pipes are thru a notch in the joists that I need to repair.
full
full
full
full
