    Dismiss Notice
How to Correctly screw an Anti Slip nut into a bolt
Discussion in 'General DIY' started by justguess, 18 Jan 2017.
  1. justguess
    justguess
    18 Jan 2017
    2
    Thanks Received:
    Country:
    Hi Guys
    Just had a quick question, how would I screw a bolt into a anti slip nut (pictured)?
    [​IMG][​IMG]
    I am really struggling to properly screw it in, so any help would be greatly appreciated.
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    72,815
    Thanks Received:
    4,168
    Crossgates, Europe
    Country:
    Cook Islands
    Those are Nyloc type nuts.
    You screw them onto the bolt with the plain metal end. The plastic gripper goes on last and prevents them vibrating loose, so often used on machinery.
    After they have been used once, you are not supposed to use them again because the plastic part is deformed when you tighten them down.
    The torque settings are not the same as for a plain nut, and if you use them again, will be different each time. Depending what you are using them for, this may be acceptable.
  4. Ian H
    Ian H
    14 Sep 2010
    7,026
    Thanks Received:
    852
    Rochdale
    Country:
    Use a spanner on each end.
  5. justguess
    justguess
    18 Jan 2017
    2
    Thanks Received:
    Country:
    Thanks guys for the responses
  6. It may seem an obvious question but here goes.....
    Are trying to screw the bolt in from the correct side of the nut? - i.e. from the back of the nut as pictured in your original post.
  7. Burnerman
    Burnerman
    7 Feb 2008
    22,987
    Thanks Received:
    4,470
    Northumberland
    Country:
    .....if the thread is correct, the nut should spin on freely until the nylon insert is reached.
    I would imagine its sorted by now!
    John :)
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
