    Dismiss Notice
How to cover off appliance sink drain
Discussion in 'Plumbing and Central Heating' started by DangerousD, 15 Apr 2014.
  1. DangerousD
    DangerousD
    27 May 2010
    20
    Thanks Received:
    Yorkshire
    Country:
    Hi all,
    I've just moved out of a rented house where I supplied the washing machine. It drained into a spur on the sink drain, but now the pipe's been removed the drain is left open and water comes out when the sink is used. It's about 2cm diameter and has the ribbed effect for flexible pipes to push onto.
    Thanks in advance.
  2. stardanny
    stardanny
    14 Nov 2007
    1,660
    Thanks Received:
    256
    Buckinghamshire
    Country:
    Go to the shop, buy a bottle of wine, go outside in garden, enjoy a glass of wine and sun, bin the bottle and use the cork to plug it in spur after a hangover :)
    Daniel.
  3. Sponsored Links
  4. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,301
    Thanks Received:
    1,709
    Northamptonshire
    Country:
    In case you're teetotal, then you should be able to get a replacement part with the end still sealed, or alternatively wrap a decent thickness plastic bag around it and secure with cable tie.
    New tenant will probably need to to connect their washing machine anyway, so it will cease to be a problem once more. ;)
  5. OwainDIYer
    OwainDIYer
    5 May 2010
    4,544
    Thanks Received:
    695
    Stirlingshire
    Country:
    gaffer tape.
  6. Sponsored Links
  7. TCCHeating
    TCCHeating
    4 Mar 2013
    2,883
    Thanks Received:
    710
    Country:
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
