How to downrate a circulator pump.
"chrishutt"
Even though the pump control is set to the lowest power (1 of 3) it's still much more powerful than it needs to be (causing a noticeable noise when running) and I'd like to know if there's a way of downrating it.
I`m throwing in a wildcard here, bear with me, might be a bit radical...........fit a smaller pump.... :shock: :shock:
The ...pump...you have ...fitted... is... too... BIG :wink:
Dan_Robinson said:
Somehow I think that might be a tad overkill for an Islongton Studio flat... ;) :D
That`s the pump he is using :wink:
That`s why I said it was too big. :roll: Read before opening your mouth :wink: it usually works for me.
Never underestimate the stupidity of your resourcefulness :wink:
For once Bumblegaspipe has a good point. Circulating Pumps make a range and I inadvertently got the SE50B (all that was on offer). In retrospect I should have got the SE20B.
Pump Type--------------SE20B----SE50B-----SE125B----SE200B
Rated Input Watts (W)-36---------96---------135---------360
F/L Amps (A)------------0.16-------0.42-------0.60-------1.60
:wink: :wink: I`m not all Charisma.
Being an installer usually has the requisite to calculate flow rates, volumes etc, & estimate pump sizes :wink: Stick to breakdowns Bud :wink: :wink:
