Hi all
I have removed a couple of vents leaving 2 x 12" x 12" holes
Have filled then with bricks and am now looking to finish them with plaster work to blend in with existing walls/plaster
Depth is approx 18mm-ish
So to plaster them can anyone off some advice on what's required please...
Wet the brick work ?
Then PVA with a mixture of ?
Should I use a browning coat and then apply a skim coat or can I use just 1 coat of some other plaster type product ?
If so how long is the brown left before skimming and is that then PVA'd too ?
Many thanks in advance of any replies
