As mentioned before, I am having 1930s brick & lime mortar walls wet plastered and I got two different opinions on plastering and I am not sure who is right.
First plasterer is telling me that he would PVA the walls then use a coat of browning and a coat of bonding (not sure in which order). Browning and bonding will stick together really well then skim it.
Second one is saying that he would use renovating plaster as bricks would suck out all moisture out of any other kind of plaster. He'd then skim that.
Next thing is uneven wall. First plasterer told me he would use sand and cement to build it up level and then plaster over that. Second one is telling me you can't do that as plaster will not stick to cement even if you scratch it and instead it has to be built up with plaster.
Final thing is room where bricks have been painted. I brushed most of the paint off but there is some left. First plasterer says he can only dry line it. Second one says, PVA and wet plaster should be ok.
Which one is right?
Which one is right?
