I have just had a new CU fitted by a local sparky. The new CU was fitted because i have a new extension and the one fuse box wasn't large enough and was a bit long in the tooth.
On testing the ring main before commissioning the new CU, the sparky detected that there was a break earth on the ring. He proceeded to check every socket and nip up the earths (in case one was loose) but the problem persisted.
To get around the problem, he converted the ring to two radial circuits (20Amp MCB).
After doing so, every socket worked in the house (and tested correctly work plug earth tester) on just one radial MCB. Thus the earth break must be between the last socket and the CU.
The sparky said that i/we really need to try and find the fault and to give him a ring when i'm decorating the front room and ripping up the carpets etc.....
But my question are (if you can help).....
1. Is there anyway of determining/detecting the last socket on a curcuit to make tracing the fault easier?
2. If he had tested every plug with the earth tester when it was still in a ring main configuration, could he not had deduced the same conclusion (i.e. there was an earth break between the last socket and the cu)
I'm not questioning the sparky as he seemed good, i'm just interested in how it all fits together and why.
