Just moved into a new-build. The builders have put strips of wood behind the plaster, above all of the window frames for curtain poles... But I tried fitting a roller blind yesterday (inside the recess) and made an absolute mess of it!
There's a bit of plasterboard about 10mm thick, and then a gap about another 10mm and then probably bricks because I couldn't drill through it.
I tried fitting plaster plugs - but they're all too long! They hit the brick so I can't insert them fully (but of course they jammed in, and I ripped out chunks of plaster when removing them
Then I made new holes and used regular wall plugs (not specific for plaster). They fit, but they're already wearing away at the plaster and the whole thing feels loose.
So what's the answer? Do I need to use a masonry bit to drill into the brick? The holes in the blind brackets are pretty small so I can't fit any big screws through them.
