Can anyone advise what fitting I should be using for a shower valve which has 3/4" female brass connectors on hot and cold inlet ?
The inlets are horizontal and the supply comes up from below, so it obviously needs to go through 90 degrees.
I've tried using 3/4" Male thread to 22mm elbow, but the trouble is when the elbow is screwed in tight it doesn't point in the right direction. Obviously if it's pointing in the right direction it will ne too loose and leak.
My thoughts so far are:
a) Washer - doubtful
b) Pack with PTFE tape - doubtful
c) Cut thread on elbow shorter - sounds destructive and can't be right.
d) Use a straight 3/4" to 22mm connector and then put in an elbow further out, but this will require a major re-route of the inlet piping and dozens of tiles to be removed.
Can anyone who's done this before help me?
Thanks,
Matt
Thanks,
Matt
