Leaking from the threaded fittings
Why don't you just swap that fitting for a bent tap connector and fibre washer ?
The nut and olive on your existing pipe will probably screw straight onto the tap connector....job done.
Sure. Sounds like a good idea. Do you have links for the actual product? It is 3/4 to 22mm 90 degree elbow connector.
Are you sure it's a 3/4 x 22mm ?.. most domestic ballvalves are 1/2 inch and fed by a 15mm pipe.
Just google tap connectors, they come in 1/2 or 3/4.
In this house, the old ballvalve has 3/4 inch threaded fitting which goes to 3/4 female threaded connector. Because the water tank has a hole for 3/4 inch fitting, I had to buy a new 3/4 inch ball valve recently, and replaced the old one. It goes to 22mm pipe.
So you need a 3/4 inch bent tap connector. As in the picture above but 3/4 inch x 22mm. Your nut and olive should fit straight on it. If not then change the nut as well.
This idea worked. It seems cured the leak. No drips or leaks for now. Will keep checking next few days.
Thank you for your vital info and advice, which was the solution for the problem.
When I tried to take off the pipes under the vertical end, I had to cut the pipe off, because the vertically connected pipe into the 90 degree elbow (same shape as the bent tap connector shown), doesn't allow the pipe in it being taken out due to the nut depth plus more of the pipe in the vertical end of the connector. For that, I had to plush down the vertical pipe for making it have space to take out from the nut, but that might damage the mains water pipe coming in vertical way. Not safe at all.
Flexi hose type connector that I used, seems a lot easy and simple to take out the pipe connected under the vertical end. For reliability, it seems bone dry with no leaks or drips, and water flows OK into the water tank.
Checked out the water tank this morning. Water was on all night for the first time into the tank since the problem started. Everything is fine. No sign of drips or leaks from the connector. Many thanks for all the info, ideas and advice.
