D
Deleted member 272719
Hi all
This might seem a simple question with an obvious solution but I'm stumped.
I'm buying a house in Spain and the previous owner has bought internal door 'packs' - prefinished, prehung doors with casings (with stops) but hasn't fitted them.
I've never seen finished casings before and I can't think of a way of fitting them. All the doors I've fitted before have been unfinished so nailing/screwing through the casing into the frame and making good before painting is ok. Obviously I don't want to do that with a finished casing. Even an 18ga nail will be visible.
The stop/slam strip does not appear removable, and there are no fixings in the pack. The finish does not appear to be primer, and the colour goes with the colour scheme.
On the hinge side I could screw through the hinge holes, or put a screw in under the hinge but that still leaves the latch side.
Suggestions?
Suggestions?
