I want to put a metal rail between two walls, there might be other bits too but basically a bar across the room fixed at either end.
I found people selling "tube clamp" products which I think is what I want, e.g: https://www.themetalstore.co.uk/key-clamp-fittings/tube-clamp-uk-suppliers
But say the span is 200cm and you have to recess each end in the wall plate... now your pipe is too long as you try to get it in. How do people do this? Similar issue to connecting soil pipes I suppose.
Even if you have a join in the middle you're still going to end up trying to force it, bending pipe that really doesn't want to bend.
Is there a trick to it that's obvious once you know?
