Hi there,
I'm thinking about cross-battening my loft so I can increas the level of insulation to 270mm, and then board over the top for light storage. But I cant decide the best way to secure the new battens..? would a few diagonal screws through into the rafters below be ok with the view that when I screw the boards down that'll hold it rigid?
Or should I use a long screw to go through the top of the new batten and into the rafter below, and then board with seperate screws?
Or should I just lay them in place and screw the boards to them which will be enough to hold it all tight?
OR, should I even bother with the cross battening to gain another 150mm insulation? Will the initial outlay for insulation and cross battens be way more than what i'll save when fitted?
Many thanks fellas, Phil
