- Joined
- 2 Oct 2022
- Messages
- 9
- Reaction score
- 0
- Country
Godd Afternoon Everybody
Our dreadful 1930 house has the front cantilevered out over the ground floor by about 1m. Part of that is filled by the bay window and the rest just hangs out or forms the porch over the front door. Having found no way to get into the floor space that hangs out (practical and political) the sensible soultion would seem to be to stick Kingspan to the underside of the hangout. There is sufficient 'depth' for 150mm. I carefully measured it all, drawin it in CAD and was amused to find that it needs just one sheet of Kingspan and one sheet of exterior grade ply. That will be painted white to give the same appearance as now.
We suspect that the existing 'ceiling' and the left side trim are probably asbestos board. Thus the principal fixing method will be a grab adhesive like Stick Like Sh*t. We are proposing to stick the plywood to the Kingspan when that is fixed and to trim the edges with 20mm quarter round beading. To fix that am proposing to hire a nailgun and get some 30mm stainless nails (I don't know if my builder has such a gun). My thoughts are that doing that will not release any fibres from the asbestos board. The side on the house could be screwed as that has a wooden trim plank.
Thus the question is "How many tubes of grab adhesive will be needed?". A second question is whether this is a sensible approach. My builder agrees that sticking it up with adhesive seems sensible but you folks may have a better solution.
Many thanks
Pete
Many thanks
Pete
