I have a leak on my bathroom sink cold water flexi tap connector just above the isolating valve. Any ideas how to fix would be appreciated thank you.
It will need replacing.
How that is done depends on the flexi and you water system.
You'll need to post more information and maybe some pictures is you want much more help.
If it is leaking from a compression fitting, you could tighten it a bit. Alternatively you could dismantle and re-assemble using a little jointing compound on the olive.
Hi thanks for replying, they are compression fittings and have already tried tightening a little more, seemed to make the leak worse, then tried dismantle and re-assemble with jointing compound still leaking
Could the washers have fallen out when you dismantled them?
