On replacing the carpet in my bathroom I've found that the flush pipe to my toilet has been leaking -- perhaps for some time. The floor's okay once it's dried out (it's moisture-resistant board), but I need some advice on how to stop the leak, please:
I'm pretty sure the leak is where the flush pipe goes into the toilet bowl. It's difficult to get at because the toilet cistern is behind a panel, and the pipe comes out through a small hole in the partition. So can you confirm that the normal type of connection for that pipe is probably simply a push-fit with some kind of an O-ring?
I guess the "proper" way to repair it is to disassemble everything and then reassemble with new rubber bits, but my system is 1982 vintage and, I suspect, imperial measurements, so the right bits might be difficult to find.
So is there some kind of putty that I can push in the joint to make a long-lasting reliable seal? Afer all, there's hardly any pressure there.
