Hi all, I'm hoping someone can point me in the right direction to fix an issue with my heating system .
A few days ago I had some maintenance done on the system (drained down, cleanser put in and later removed and rads jet washed out to clean sludge ) . Since then I have noticed a very loud gurgling /water rushing sound . This seems to be coming from the cylinder and seems to happen once the boiler has stopped . Even though the boiler has stopped the external pump seems to still be running , the noise continues until the pump stops . The noise is very very loud, I will try and record on later if it helps . I have done a quick Google search and it seems it may be air in the system , would this make sense? I know there are 2 bleed points on a vertical pipe next to the cylinder so I could try and open these until water comes out but thought I'd better take some advice on it 1st , can anybody advise on this please ?
Thanks in advance for any help
