how to glue inside glass to oven door?
8 Aug 2007
folks, the inside piece of glass on my oven door as come adrift at the bottom and both sides, just attached at the top. I have found some high temp sealant to reseat the glass, but cannot figure out how to get the glass back in position for the sealant to set...the glass keeps falling away. Any clues?
You have to take the door apart, clean the glass and the area it is to be glued to. Run the bead of glue onto the metal surface, place the glass on it and then sit a fairly heavy weight on it and leave for around 24 hours to cure.
Did this with Indesit doors years ago, never had a recall on them.
What sort of sealant did you use?
I've been recommended neutral cure black RTV silicon.
Do you know where I can get this from?
A kit is available specially for the repair of oven door glass where the glue has failed, the kit includes the correct heat resistant adhesive
To carry out the repair it is best to remove the oven door, see the Remove oven door video
Once the door is off you should be able to remove the fascia glass by accessing the screws that are normally found on the bottom edge of the door which hold brackets screwed to the inside of the fascia.
You can then access the glass inside the door.
