Hello
I have a vintage model train and I need to grind about 0.75mm off the flanges/edges of each wheel so that it will run on modern track.
I have put a wheel onto an axle and then put that in an electric drill and tried running it against a metal file, however very little comes off the wheel, it just grinds holes in the file. I've been told this is because the wheels have been hardened.
Please can you tell me what I can use instead of a standard file that will make an impression on these wheels?
I thought about trying a grindstone, but if so what type would you recommend?
