How to make floor to skirt joint good without removing skirt
7 Sep 2004
Hi Guys
About to undertake my 1st ever floor tiling job. My kitchen,small utility and hallway. Someone told me to take off skirt,tile to wall and replace skirt on top. Skirt is stuck with adhesive and already level with block jamb thing so would look a bit mad if raised. I have read that I should put caulk not grout in join but don't know how to make finish look professional eg can you get grey caulk to match grout?
Also anyone know how join floor tile to bottom stair, which is carpeted, and make it look good. You guessed it, I like things to look good. Any tips would be appreciated.
Colette
the only comment i can make is you will have to lift the carpet up
lay tiles then fold / cut carpet to sit on top DOO NOT for gooord sake
try to tile up to a carpet :roll: :roll:
good luck
big all
You could paint the caulk the same colour as the skirting board (if it is not unpainted that is) rather than try to match the caulk with the grout.
