How to plumb a new sink in the garage
25 May 2011
Birmingham
I want to try and install a new sink in my garage. The other side of the wall is my washing machine with a hot and cold feed and a waste pipe which goes through the wall and down the side wall of the garage outside.
My combi boiler is also in the garage and hot/cold water pipes (separate to the washing machine pipes) also run up the garage wall to the house.
I assume I can connect my sink to the existing waste pipe in the garage that the washing machine uses?
Can I also feed off the hot/cold water pipes that are the other side of the wall? I can't see an isolation valve, so do I turn the water off at the mains, drain the system, then do I cut the pipes and fit a tee on each pipe to go through to the garage?
Is it as simple as that?? I'm guessing not...
Any help appreciated.
You can make thing complicated if you want, but I cannot see anything wrong with your list. :)
Little need to drain the system, as your cutting into the hot and cold pipes which are off the mains - as they are going through the combi. Any little water that is still in the pipes can easily be collected in a suitable container. Open up all your taps first after you have turned off the main stop valve.
If your boiler is on the correct side of the garage wall you can probably tee into the cold inlet and hot oulet from there. Its a bit difficult to say without a photo.
As its in your garage, I would fit a dry trap like a hepvo as you will be unable to protect the water seal from frost.
And a Hep V O is always good when teeing 2 wastes into 1 :idea:
