How to refix kicker boards now base legs won't fit
27 Mar 2008
Leicestershire
I have just installed laminate flooring in my kitchen diner, some of the kitchen base unit legs will not go back under the units into the leg sockets which click into the bottom of the base unit. So i have screwed them up against the base units on their own!!.
My problem is, the kicker board used to be held in place by being clipped to the base legs.
This is not possible now, as the legs won't relocate back into the base leg supports due to the reduced height between laminate floor & underside of base unit.
Whilst the units are screwed to the walls & supported by weight onto the adjustable legs, if I try to push the kicker board clips onto the legs they just get pushed under. Whats the best way to support the kicker boards now, so that they all sit back at the same depth around the units.If there another method or attachment i can make or buy?
Thanks in Advance
Hey Whitehaven, are you lost in the forum jungle?
Us here at Electric UK aint interested unless you can plug it in.
