I had another post but wanted to start a new one as this may help others ....
I have a radiator that I want to replace the TRV Valve and be useful to know if there is a difference for the Lockshield valve replacement.
I want to do this and not drain the whole system (although I have the tools to do that and knowledge how to re pressurise)
(I have recently removed , replaced a radiator , bled rad and depressurised)
Task:
15mm pipes , Combi boiler , Radiator at bottom of house, Has TRV and Lockshield valves.
Method / How:
- If I turn off all other valves TRV and LS can I if quick swap out a valve ? If I had a plumbtub to catch water ? I really don't want to drain system (I fear that for some reason)
- Is there a bung I can use to stick in the 15mm pipe or rad end briefly to help ?
The question is how can I do this easily ?
Also if the rad had 8mm microbore pipes are there any precautions taking time ff that type of valve ?
I'd so appreciate your thoughts !
Task:
Method / How:
