    Dismiss Notice
How to remove plastic fasteners / rivets in Bosch washing machine door
Discussion in 'Appliances' started by strugglingdiyer, 2 Nov 2020.
  1. strugglingdiyer
    strugglingdiyer
    29 Mar 2014
    26
    Thanks Received:
    Pembrokeshire
    Country:
    I'm aiming to replace the hinge on the door of a Bosch WAQ283S1GB/01 washing machine, with the hinge carrying a part number 9000463344. I have found an equivalent part on ebay, but when I removed the door I found these little plastic fasteners instead of screws.
    I thought they might be pop rivets like those you sometimes see on bike fairings, but when I applied pressure through the central hole nothing happened.
    Does anybody know how I can safely remove these and whether they can be reused?
  2. Lower
    Lower
    22 Dec 2005
    1,880
    Thanks Received:
    261
    Leicestershire
    Country:
    I don't think they can be reused. You'll need to drill the heads off and then replace with new rivets or nuts and bolts.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. strugglingdiyer
    strugglingdiyer
    29 Mar 2014
    26
    Thanks Received:
    Pembrokeshire
    Country:
    Not what I wanted to hear, but thanks! Not sure even how to identify them. Head seems to be 8-9mm across with a 2mm hole...
  5. foxhole
    foxhole
    14 Mar 2006
    17,219
    Thanks Received:
    1,981
    Kent
    Country:
    Drill out with 3mm hss bit and replace with self tappers.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
