    Dismiss Notice
How to remove this toilet (no screws/bolts)
Discussion in 'Plumbing and Central Heating' started by smp50, 12 May 2014.
  1. smp50
    smp50
    10 Jan 2013
    379
    Thanks Received:
    5
    Country:
    The screw holes on this toilet pan are filled with some hard material that can't easily be chipped out. Either it's covering the screws, which seems very odd, or just plugging the empty holes and the pan is fixed to the floor some other way?
    [​IMG]
    How am I going to remove this, smash it out?
    It's sat on a "concrete" floor and tiles were butted up to it, they don't go underneath.
  2. Sponsored Links
  3. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    Looks like it's been bedded on cement so hammer and chisel and protect from flying bits.
    • Thanks Thanks x 1
  4. smp50
    smp50
    10 Jan 2013
    379
    Thanks Received:
    5
    Country:
    Every job seems to come back to that.
    (You should see my electrics!)
    • Thanks Thanks x 1
  5. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    lol, see whether you can get a bolster under the edge it may break the join in one go,
  6. smp50
    smp50
    10 Jan 2013
    379
    Thanks Received:
    5
    Country:
    ok, thanks. I won't be doing it for a few days yet, need to make sure I'm ready for the new toilet. But that does depend on the state of the floor underneath, I suppose.
  7. Sponsored Links
  8. stardanny
    stardanny
    14 Nov 2007
    1,660
    Thanks Received:
    256
    Buckinghamshire
    Country:
    You can use Jet Cem, a quick drying mortar to prep floor, smooth out, where pan will sit and fit pan with screws.
    Daniel.
  9. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,079
    Thanks Received:
    2,015
    Hertfordshire
    Country:
    Stand in front of the toilet and kick upwards under the bowl, they normally 'pop' off.
    Andy
  10. +1
    (wear decent boots though!)
  11. If its on concrete, its likely there will be a big blob of sand and cement/concrete underneath which will need removing.
  12. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,378
    Thanks Received:
    1,734
    Northamptonshire
    Country:
    Cant see the outlet, but if it's an 'S' trap, (goes straight into the floor), be careful you dont lose any bit of broken pan down the drain. If it breaks, (and you'll have to smash it if the outlet is cemented into the drain), wear suitable gloves, broken porcelain is as sharp as broken glass!
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
