Silly question, but do you re-string a roatry clothes line from the outside (wide bit) in to the middle (thin bit) or the middle outwards??????
Is there a correct method???
When I done mine I started at the middle and went around and around until I got to the outside. Pull it as taught as you can. You may need to re-tighten it afetr a week or two if it sags a little.
