Good evening!
I have a 18-25 Worcester Greenstar Heatslave Combi. The pipe connections are 22mm flow/return and DHW with a 15mm cold. Also 15mm blow-off pipe.
Problem is, the end stubs of all of these boiler pipes are SO SHORT!!
They do not clear the boiler itself and are set very close to other components/wires. I want to solder them in place for a professional job but blow-torch heat is problem??
Any suggestions?
Mike
Any suggestions?
Mike
