I have searched through dozens of threads here without coming up with a solution to this one. I found some links to data sheets but the pages were no longer available.
I prised out the plastic plug on the on/off valve expecting to see a screw securing the head of the tap but no - just a shallow conical indent on the centre - so how do you get the heads off?.
The bezels under the valve heads appear to just turn with screwing in or out.
There is no access from the rear - it's all flush onto the tiles.
The reason I want to strip this is because there is very little flow through the cold valve despite similar pressure available to both hot and cold.
The flow valve can just turn and turn - only the first 90 degrees or so seem to do anything but it does turn on and off and does not drip. just does not seem to open fully on the cold side.
As always - any help gratefully received
dfoss
(when you get to my age every day is a new experience)
dfoss
