HOW TO TAKE THIS OFF (with pic)
If you were able to explain yourself better then I might be able to help!
well the nob on the tap doesnt stay up when i lift it so just asking for some kind help what i can do to fix the problem also how do you take the nob off?
thanks
you need the tap to be running and half decent pressure then the knob will stay up until you shut the tap off.
Probably the water pressure is too low, remove the valve and take out the spring...should then be ok.
I have never seen one removed so cant help you there, try taking the shower head off and see if the knob stays up.
Some were fitted with a grub screw while others will unscrew , some of the cheaper mixers will just pull off with a sharp tug.
where can you find the grub screw? and what direction do you have to twist the nob to take it of?
thanks
The grub screw if fitted will be on the nob , if not try screwing it anti clockwise while nob is raised & flat blade holding spindle from turning , they can sometimes be a bugger to get off.
You may be able to lift the divertor enough to be able to remove unit from mixer.
the spindle doesnt turn i tried turning it anti clock wise but no luck just keeps spining for ever looks like new taps now
thanks
just took it off using pliers does any body know what this part is called and where you can by it from
thanks gents
Different deck mixers will use different diverters , more than likely the O ring/washer has perished , good luck. :wink:
