    Dismiss Notice
How to tell if plasterboard contains asbestos
Discussion in 'Decorating and Painting' started by PASUK, 12 Mar 2018.
  1. PASUK
    PASUK
    13 Feb 2014
    106
    Thanks Received:
    Buckinghamshire
    Country:
    Hello
    I am getting my kitchen modernised and as part of that process I am having a boiler moved.
    Pipes need to be routed in the ceiling between through joists. and down to the new boiler position. No access from above so we are planning on cutting out a section of the ceiling to run the pipes.
    My ceiling has artex, likely to have been applied a long time ago so I am almost certain the artex contains asbestos. The plan is to use x-tex to remove the artex from the ceiling first. The plan is then to cut out the section of plasterboard cutting along where the artex has been removed which should be a safe way to go about this.
    However, I don't know if the plasterboard under the artex itself contains asbestos and therefore unsafe to cut out. The house was build in the 50/60's timeframe.
    Any advice please?
  2. TicTac
    TicTac
    21 Feb 2018
    391
    Thanks Received:
    68
    Country:
    The plasterboard, or whatever's up there won't contain asbestos. You can use a wallpaper steamer to take off the artex. It'll soften it so it can be scraped off, and in making it wet, it won't get in your lungs.
  3. Sponsored Links
  4. Why not get the Artex tested then you'll know rather than assuming?
  5. Robbie uk
    Robbie uk
    9 Apr 2007
    2,059
    Thanks Received:
    267
    Cheshire
    Country:
    Don't think plaster board has ever contained asbestos.
  6. Sponsored Links
  7. TicTac
    TicTac
    21 Feb 2018
    391
    Thanks Received:
    68
    Country:
    Why bother; it still has to come off, and the steamer method stops spores getting into the air - whether there is any asbestos or not.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
