How to tell LED GU10 Dimmable or Not?
15 Apr 2008
Devon
I have some LED GU10's and have thrown away the packaging. I cannot see on the lamp anything to say if they are dimmable or not.
I have one I know is and one I don't know for sure.
Is there any way of telling, apart from putting them in a fitting and seeing what happens. If I did that will it knacker the lamp/dimmer if its not dimmable? (Its a LED dimmer)
David
EU regulations state it must state if not dimmable. So
must be displayed if not dimmable.
However in real terms to dim a low wattage lamp is not easy. In the main it means neutral supply to dimming switch which is not normal. We use protocols like 5 ~ 20 mA so first 5 mA is used to supply the device and the 5 to 20 mA says how the device is read. This means first one watt does nothing only over one watt will the light come on. And limit is 4.5 watt so not really a good system. So one has to use a dimmer switch and bulb which are matched so although bulb is dimmable, it does not mean your dimmer will work with it.
Then use the unknown one somewhere where it won't be on a dimmer and buy a replacement. And if you have multiple lights on one switch, I'd not be surprised to learn that it is advisable for them all to be the same.
