LED GRID DIMMERS
STI
5 Aug 2009
Birmingham
Does anyone know of a grid system fitting LED dimmer switch, Its for GU10 LEDs that are replacing GU10 Halogens. These are currently dimmed by a toroidal dimmer in a grid plate.
I still want the LEDs' to be dimmable as its over a dining/relaxing area.
For information the grid plate is a four gang populated with two dimmers and two standard switches, the standard switches are for the 2 way operation of the other GU10 LED's on a V Pro single gang standard dimmer fitting.
28 Jul 2006
Oxfordshire
Richmond have produced a dimmer (Grid 500) to use on CFL and LV lighting including LED. It has a small adjustable trimmer on the side so you can set it up with the load
  • Thanks
Reactions: STI
STI
5 Aug 2009
Birmingham
http://www.tlc-direct.co.uk/Products/LTGD120U.html
Thanks, i looked at this and was put off by the term specifically designed to work with LEDlite LED. I sassumed this was a particular brand and it isnt the ones i have. I also wasnt sure about the Ultimate Grid reference. I have no idea which supplier made the grid plate i have. Looking at the picture the shoulder of the switch seems to have rounded corners, the grid plate and yolk i have has square corners.
15 Jan 2008
Called 'Zano' now I think, but the same product. Also, these come with a number of different faces to fit different grid systems.
  • Thanks
Reactions: STI
