How to test a ring main
30 Mar 2015
I am in the process of laying out a number of ring mains in my house (renovation...) and once the circuits have been connected to the consumer unit and certified (by electrician), I would like to conduct a further round of testing to make sure I haven't done something wrong and specifically, that a cable hasn't popped out of the screws of the socket connection. I know this will be picked up by the electrician but I am a bit like that....
I have seen that you can buy the "testers" that you shove into the socket and wait to light-up and make a certain buzz. Is this what I should be using or a multi-meter of some description?
This knowledge will also be helpful to test existing ring mains too.
Testing of any circuit is done to check all of the wiring BEFORE the circuit is connected up and energised!!!!!!
There is a particular way of testing ring final circuits. Check it out before proceeding. And you will need a low ohm test meter (i.e. it will be calibrated and accurate and designed to display resistance measurements of less than 2 ohms.)
Those "plug in" testers will NOT tell you of many problems on a ring final circuit, as I say, testing is done first before switching on. Those testers need power to be present for them to work.
Have you found an electrician who agrees that it works like that?
Because it doesn't.....
I'm sure a number of us have an idea of what you are like.
http://www.tlc-direct.co.uk/Book/8.1.1.htm
www.ebay.co.uk/sch/i.html?_odkw=(metrel%2Crobin%2Cfluke%2Cmegger)+(installation%2Cmultifunction)+tester
Other makes are available - I just picked the most common ones.
Thanks for the responses. @TTC, the link was very helpful.
@banallsheds, That ebay link draws a blank. Can you re-send please.
I have an electrician lined up to support me during the installation of the rings and then to connect them in as well as certify.
Could be the site mangling URLs
Paste this into the search box on ebay: (metrel,robin,fluke,megger) (installation,multifunction) tester
