My question is trying to understand why I have two loops upstairs for one ring main....
In process of changing single for doubles and adding a couple of spurs on the upstairs ring main. I've done the following tests:
1) Fuse off on MCB (marked upstairs sockets) and every socket upstairs is without power.
2) With the fuse still off, voltage test (no power) and continuity test on 2 disconntected lives at one of the sockets (all other sockets off and nothing plugged in). Ring main.
3) With the whole main board off, continuity test on 2 live feeding the fuse - Ring main. Also tested the 2 neutrals from the corresponding 4mm cable - Ring main.
So it all looks like a ring main, but I have 4 cables running into the cavity wall upstairs which I then assume lead down to the MCB - I can't trace the cables any further. In effect giving 2 loops upstairs. The only reason for this I can think of is that the ring main was actually looped all the way back down to the MCB without actually being cut and connected to the board to allow a quick and easy way to create a 2nd ring upstairs should the need arise? Is that common practice? Or could the the two loops be joined before the MCB - there are only 2 lives on the fuse for the ring main in question? Or would this frazzle?
Thanks for any suggestions on what might be happening!
Elliott
Elliott
