how to test wiring
2 Jun 2005
Coventry
currently decorating for a friend, and they have a broken wall light fitting. apparently it's never worked, so we're unsure as to whether the wiring is even live.
how could we check? an advice most appreciated.
Anna
Is there a switch or pull cord?
Simplest way is too use a voltage detector/indicator; with a detector move the test equipment around the cable and see if it lights up and makes a noise. If you are using an indicator check across Live and Neutral in the ceiling rose/junction box.... These peices of test equipment are easy too get hold of and cheap.
hope this helps.
Carlos
