The spindle on the hot water tap of my monobloc bathroom mixer tap is loose (though only two years old!!), but there are no drips. If I unscrew the casing (see attached photo--the tap is in front of a mirror, by the way), I can see a large nut (about 18mm A/F). Is this what needs to be tightened? If so, the clearance is too narrow for a normal open-ended spanner. I'd need one about 4mm thick. Do such things exist?
