I think the soil pipe is blocked because all the bathroom drains are all slow and flushing the toilet makes water spurt up into the bath from the drain.
I've tried a metal flexible snake thing but that didn't work. Plunging doesn't work.
Ideally I could put drain rods down the top of the soil pipe. But I have an attic conversion so they cut the soil pipe and put a durgo valve on top under the attic floor boards. They're not boards I can pull up, have to cut an access hole. So it's hard to get above the soil pipe.
I can reach across under the attic floor from the eves and pull the durgo valve off. There's then about 3 or 4 inches from the soil pipe to the floor boards above.
So I wondered if there's anything else I could shove down over the top of the soil pipe which would bend 90 degrees over and then a long way down the pipe that I could then move around to unblock it. I thought I'd try the metal snake thing I have but it's probably too flimsy.
