How to use these reducers?
23 Jun 2014
Staffordshire
Sorry is this is really dumb but want to make sure I get it the right way round. I have a 22mm PRV that includes reducers for 15mm they are similar to these at B&Q.
Can someone tell me the correct way to put these in please?
Why are you wanting to use reducers? They can be hit and miss at the best of times, better to get a PRV that is sized to the pipe you're using.
Because the pipes are 15mm. Just seeing how I go for now, just in the middle of a few things and want to check and potentially change the water pressure and it wasn't much difference in price than going for a pressure tester, which would then mean i would have to go on and then get the TRV anyway.
Just want to fit it first, may be temporary, just need to know how to use the reducers
Sorry, I understand why you wish to use reducers, they're just not the best things to fit, is what I mean. They can be prone to misfits and leaking. They should come with fitting instructions tho?
Why not just get a 15mm PRV instead?
