How to wire a PIR to 1way light
15 Jan 2010
Middlesex
Help Me please Guys
In my porch i have a ceiling rose lamp and wall switch.
I would like to put in a ceiling PIr but can over ride it with the switch.
step by step please and what cables go were,
Thanks Guys :P
Two lives to the rose. One through the wall switch and one through the PIR switch. The rose and PIR will need a neutral. All 3 will probably need an earth (if metal conductive enclosure).
If you can run to the back of the wall switch all will be their for you to connect the PIR. depends on the original wiring layout
What do you think?
Leave all existing wires where they are.
Take a 3 core to the PIR from the rose and attach to the existing terminals:
N to N
L to Loop
SL to SL (the live terminal the bulb is connected to).
