How to work out the size of tap connectors
17 Nov 2008
Kent
This is a daft question I know but I have a tap (European) with connectors and I am struggling to work out what size the connectors are. Ideally I want to convert so that that I can connect to my 15mm isolator valves the ends of which are too large for the tap connectors.
The internal diameter of the connectors appears to be 15mm.
In the UK, you only get 3 modern sizes - 3/8" - 1/2" - 3/4"
If the female end of the tap tail won't fit on a standard 15mm ISO as the threaded end is too large then it will be 3/8", just need to get a 15mm>3/8" tap tail adapter.
th
